small oil leak
datruodb
Addison, TX
Have noticed two small marks on my garage floor on the passenger side. I will be changing the oil next weekend. This will be my first time changing it. Are these cars notorious for having faulty valve cover gaskets or oil cooler lines that leak? Just trying to be prepared. Thanks in advance
2easy
Calgary AB
valve cover gasket or oil cooler lines. Thought mine was cooler lines but after closer look it was the valve gasket. Torqued it up and there is balance back in the kingdom.
D
datruodb
Addison, TX
It's an 06. I was just assuming since there were two spots it was most likely oil cooler lines.
Thanks guys
dester243
My DS valve cover gasket looks like it's leaking a little also. That or the oil cap isn't sealing 100%. Anyone ever seen it leak @ the oil cap?
swexlin
West Chester, PA
I have an 03. My cooler lines leaked a couple years back. I also have a tiny leak somwhere around the pan gasket. Never enough to drip on the floor, but there is a tiny amount on the bottom of the AC cooler line.
2easy
Calgary AB
Have not come across the cap leaking, but it could I guess. Check if the cover is torqued to the right specs. That is most likely where the troll is hiding.
Steve M
Dayton, OH
swexlin
West Chester, PA
Anyone have a photo of what we're looking at? Diagram?
Luigi93
