SOME 01 VIPERS HAVE BAD WATER PUMPS!!
V
Viper Wizard
South Salem, NY USA
CAP,
i guess it was only early made 01's what was your build date?
The build dates have nothing to with the bad w/pumps! They could be on any 00 or 01! How many, they don't know! Or when they may give trouble? :eek:
VPRGTS
StL, Missouri
Someone is going to get hurt. Failing water pump and resulting overheating will put coolant in front of your right front tire.
Try braking or making left hand turns at the track with coolant under your right side tires.
Trust me, it does not work as I found out this past weekend.
'01 GTS going in the shop today to have water pump replaced (and coolant overflow moved).
This should be a recall before a person is hurt and/or property is damaged.
sham5430
