SRT-10 "Start" button for a GTS
96GTS
Dyess AFB, TX
Does anyone know how much of a pain it would be to install the "Engine Start" button on a Gen II? My father has an SRT-10 Ram and that thing is too cool! The only thing that concerns me is the electrical aspect.
V10SpeedLuvr
Well, now that I think back, I quit using it because when using my autostart remote, it would crank the car too hard (you know when the starter makes that noise when you try to crank a car thats already started). Back then, I used my autostart all the time, so we ended up disconnecting the switch. I've since quit using the autostart and just been cranking as normal for a while. You've given me the idea to hook the switch back up just for the heck of it.
1TONY1
Dalton Ga. (Chatt. Tn.)
That wouldn't be very hard at all. A simple relay would work fine. I haven't looked but is there a nice spot for the button in a gen1/2 ?
Of course, like a gen3.....if you are turning the key anyway............... :D
I know...it still is cool ;)
Obsidian
Morris County, NJ
Not that I know how to install it, but the prior owner of my Gen II GTS installed a push start. He put it where the cigarette lighter is. I will try to get a photo up.
2000_Black_RT10
Up North
Not to say that it isn't cool, but what is the deal with the start buttons on cars these days? I mean, it's a car for gosh sakes, not a blender...
I have to admit, you made me laugh, the blender comment. :rolaugh:
I know this isn't a Viper, but for the last car I built, it needed a button to start it. Personally, I would like a button to spin the motor to prime it, then ignition secondary. Here's a goofy video I had to make for a buyer. The problem was that the 572 c.i. / 9.4L Hemi could kick back and strip the ring gear teeth if you tried to spin the starter and hit the ignition simultaneously with a key. It happened, not so fun taking it apart.. I needed to spin the motor, build up inertia, then hit the ignition. It was a normally aspirated motor, approximately 800 hp.
That's the story on my hot rod blender! :2tu:
http://www.wincom.net/mnllehti/footage_starting.wmv
Other than a button to start the car, I do prefer a key in the dash like my wife's Corvette rather than the steering column ignition. Yet, it's not perfect because we did have a recall on the Corvette, there is an electric solenoid in the steering column that locks the steering when the car is parked (since there isn't a mechanical ignition lock in the column), and it had to be disabled because it may accidently engage the electric solenoid steering lock at low speed while driving..
Warfang
California, East Bay
Yeah, I though it was lame the Gen3's still had to turn the key. I drove my friend's SRT in a couple autox's... spun out once and the engine died. Took me a good 5-10 seconds to remember to turn the key and re-press button.
I like the cars where the key is a passive device that the car detects and will allow you to push the start buton.
2000_Black_RT10
Up North
The passive device sounds good with a button. How does it work for accessories other than the ignition, i.e. windows, radio etc. ?
1Need4Speed
Houston, Texas, USA
I went to Honda's website and ordered an S-2000 Start button and had my stereo guy install it in the cigeratte lighter. Start button $40.00 Labor $50 bucks.
It works great. The key is in and turned to the "on" position then press and go:drive:
Sorry SRT-10 guys but my button is bigger:headbang:
VIPER BAZ UK
ENGLAND
Cool pic....
Could it fit where the electric mirror toggle switch is.....
Or some where where you dont loose any thing ?????
ROIII
