Stalling problem
Ag's'95
I have a '95 RT/10 that periodically stalls when I depress the clutch to come to a stop. Ie. stop signs etc. I have cleaned the AIS housing and replaced the AIS motor which did help but I still get periodic stalls. For example I drove it to work this morning, about 1 hr, and when I got to the office parking lot it stalled a couple of times. I am new to your forum but would appreciate any help or suggestions.
Rollin4
Anacoco, La.
Had the same problem. Here is what fixed it. Remove air box and clean throttle bodies with a cleaner. Remove Idle Air Control (IAC) be careful not to damage or loose the O ring or the gasket on the engine block and clean the carbon build up inside. Once cleaned reinstall IAC and air box. This should fix your problem.
A
Ag's'95
thank you both for the input. I will clean the throttle bodies as well as synchronize them. Hopefully that will fix it.
jgfurr
Katy, Texas
When cleaning the IAC, don't move the piston. If you do, the idle will be off and you'll definitely need to disconnect the battery and reset the PCM.
A
Ag's'95
I have replaced the IAC and cleaned the body that it sits in, but did not "reset" the PCM or disconnect the battery. The problem did get better but did not go away. Should I go ahead and disconnect the battery? Will this reset the PCM?
LETHAL GTS
Winnipeg, MB
Just disconnect your battery for about 1/2 hour. Then reconnect your battery. After some hard driving you should be good to go.
A
Ag's'95
No modifications engine or otherwise. I will make sure everything is clean as well as disconnect the battery tonight.
A
Ag's'95
cleaned throttle bodies, reset PCM and things seem to be much better. Idle is much smoother and no stalling. Thanks to you all for the help.
wrm92
