red97vipergts
- Joined
- May 17, 2010
- Posts
- 6
- Reaction score
- 0
I have a 1997 GTS. A couple times I've turned the key nothing happens (wont even turn over), but it still has full power . Then I turn the key and it will start .Doesn't matter hot or cold engine . I could not get it to repeat the problem all the time . Finally in the garage it did it again and I could not get it started . I jumped the clutch safety switch and it fired up . I changed the switch and everything seemed to be fine for a while . Then it happened again .I tuirned the key and kept pushing the clutch pedal to the floor and it started . Then I turned it off and it wouldnt start again . This time I jumped the switch and it took a few seconds and what seemed like a couple clicks and it started again . I do not believe it was ever the switch , I think it is the starter or possibly a relay . I know alot of people have similiar problems with the starter but only when its hot . My car will do it whenever ift feels like it hot or cold . Should I just change the starter ? Any advise would be appreciated. Thanks
