Steve Vipair
M
MarcRoth
Guys....At only 900 miles on the car my wife thought i was nuts but put it in the garage and tore into it,, Raised the compression, changed cam profile, ported heads,{ Took a doner head and cut it in two to get the max from the castings} Kooks headers and good owl fashion unleaded race gas seeings that when I drive it I want know problems with octane. And a good Tune. Marc
ROCKET62
Has Left the Room!
Phoenix, AZ bye-bye IOWA
Since there was two posts covering the Coupe Rear End, I copied my other reply here as well:
Re: What Dodge should of done...
Originally Posted by VicTxV10
Did you have all the new panels painted first and then install them or was there some fitting/finishing that needed to be done first?
You have to remember this is an aftermarket body kit - not oem replacement panels. With all aftermarket kits, there is going to be some degree of work required to get the proper body gaps and lines. I did purchase the kit from Steve as I believe the coupe rear end looks amazing on the Vert and is definitely what Dodge should have done in the first place.
The overall quality of the panels in my opinion are good. There are a few areas of concern that I have and I'm not quite sure what suggestions Marc made to Steve for improvements - as I have also provided some feedback to Steve as well. As I am rebuilding a wrecked Viper I did expect some additional work would be required to get the alignment of the panels perfect - but there are a few things that are not coming together as "un-bolt old panels, bolt on new panels" as suggested. I am very close to the final fit before sending off to paint - and it will be interesting what the body/paint guys think about the quality of the panels and the gelcoat primer that comes on the panels. I'd be happy to share additional thoughts comments via pm for those with specific questions.
Hope to have mine done and back on the road in 6 weeks.​
ROIII
