Stop Tech or Brembos?
BADVENOM
port washington, n.y. usa
Okay I presently have original calipers with Baer Eradispeed rotors all around. If I was to convert to either of the above do you guys recommend one of the other and why? Also would you do all four or only the front or rears..Thanks for he input!
Adam
Chuck 98 RT/10
tampa, fl USA
Seems to be several post on this topic lately. Do a search if you don't get your answer.
What is your application? Street, road, drag or pose?
MannyC
San Diego, California
Don't go Brembo if you are not going to be tracking your car ALL the time. I have them on mine, but my car is mostly a road course car. Squeels all the damn time and there are no pads I can put on it (that I have found) that won't scqueel.
Bugeater
Virginia Beach
What about Wilwood? Pad replacement for the 6 pistons on all 4 corners was something like 180 bucks!!!
For Stoptechs, its around 225 fronts, 150 rears.
riverflyer
Mendocino, on the lovely North coast of California
Now theres a direct question (and a good one)for you!! Chuck, speaking of search, I have used this many times and usually do not get any matches, even when using key words that I know have been topics lately. On most boards, words like those would generate several pages of results. Am I missing something about the process? thanks, John
Chuck 98 RT/10
tampa, fl USA
No John, you're not missing anything. The search functionality on this site is horrible. But sometimes it returns something so it's worth a shot.
KepRght
CA (925)
I too was wondering the same thing, Brembo or Stoptech, after a buddy put 19" HRE's with 15" Brembos on his 01 porsche Turbo it was all over for me! Sick.. Sick.. Sick.. the improvement in brake power was neck snapping and the look is jaw dropping even considering this is 911TT brakes we are comparing to.
Photos please! I can hear it
here we go
http://hobbystage.net/porsche/msindi/
KepRght
CA (925)
forgot to mention they are 8 piston fronts, do the 15's on the front and rear with a proportioning valve to kick more brake to the back like i did on my 98 vette and you will stop on a dime. Consider this setup, I know I cant stop thinking about it along with a T T kit so I can put the smack down on these pesky 911's that are kicking out 750hp with AWD and 15" brakes.
Fiorano
Vienna, VA
The brakes look great, but that set-up must be over $10K. Know the cost?
malcoll
Jacksonville Florida
Do you have Wilwood brakes on your Viper? If you do.... is it a Gen I... or Gen II..... where did you find them and how much for a four wheel setup?
Thanks in advance!
Lance
RedGTS
Tennessee
The SRT Brembo conversion package for Gen. II's appears to be coming soon. You may want to wait a couple of months because it should outperform all the currently available aftermarket systems at a significantly lower price.
KepRght
CA (925)
this gen3 conversion uses the stock srt-10 brakes? or a gen3 brembo kit retrofitted for the gen2?
RedGTS
Tennessee
From talking to the two different people that are currently developing the conversion kit (at least one of whom is working with PVO), it will use the SRT rotors & calipers along with new knuckles. The reason the SRT setup won't just bolt on to a Gen. II is due to the knuckles being different. Also, the '01+ ABS cars should be able to use their OEM master cylinder, while the earlier cars will also have to have a new master cylinder. I'm also very interested in this setup and will stay in touch with both vendors and post anything else I find out.
Gavin
Monterey, Ca, USA
snakeoil folks just announced the 2003 kit for most vipers
no price advertised but this kit has to be cheap given the cost of the 03 calipers, pads and rotors.
Believe it comes with a replacement master cylinder to make it all work properly
