MES
I'm thinking of getting some new rims and brakes so I wanted to see if anyone else has tried the following:
97 GTS with stock 17" rims
1. If I get 18" HRE 547 rims and Stoptech rotors/caliper/pads all 4 wheels, will they fit? Same size rims as the newer stock 18" cars. I think yes they should.
2. Can the 17" stock rims 10X17 (front) fit on the rear with StopTech? I want to put drag radials on the stock front rims then mount them on the rear. I'm not going to drive around with the drag radials on, except to and from the track.
3. Will 18" pilot sports in the front and 17" drag radials in the rear cause the car to get "loose" or difficult to control running the 1/4 ?
4. would BFG drag radials be the best 315/35/17 or is there an 18" or something else you would recommend. Do theses tires have as much "bite" as a true racing slick, I don't really want to start breaking stuff.
5. Are multi piece rims like the HRE's legal at a drag strip or road course? I thought I remembered seeing somewhere that the rims must be welded, could be wrong.
Any comments welcome, Thanks.
