I figured it's going to be less effort (for me
to produce plans rather then to arrange production so there it is:
I used 1/2 inch MDF.
Some pieces have angle cuts - I deemed this necessary in order to get adhesive sealant a space to work thus keep the structure airtight. I am not saying that without these and with plenty of sealant the box wouldn't be airtight, I just don't know.
Upper hole - this is for sub terminal, a $5 item available in most stores including Best Buy installations.
Lower hole - made for the woofer.
Cutting out the original hole in the stock back panel is a must - it is smaller then 8 inch woofer and protrudes towards the box so it would damage the new woofer.
Brace holes (bolts sub to the firewall) - position them according your specific padding. I mentioned that it is vitally important to pad sub from your firewall - and this will affect the exact placement. I used window/door weather stripes - use whatever suits you best.
Sealant - don't use glue, its not gonna work. You need to use sealant also because your pieces will have greater tolerance, remember this is a home made kit and not laser precision cut. So there are going to be clearances between parts and these need to be filled. Glue tends to shrink. Also - the woofer pumps air and creates tremendous stress on the structure - you want the box to be airtight. And you must use nails/screws to support joints. I used adhesive acrylic sealant. Use whatever will work for you but use plenty of it. I put the box together first, let it the adhesive cure and then applied nails.
The most important thing - a subwoofer: There are only several shallow mounts on the market. I used a brand new Kenwood Excelon 8 inch. It might be difficult to get it since it is so new. I paid $200 in local store, online price will be lower, I expect around $120 once available. I can't vouch for any other woofer so don't crucify me in case you won't be satisfied using some B grade. Get the Excelon, currently it's the best shallow mount.
As for my rears - I put there Excelon 4x6. I had to remove the plastic brace which also - in part - supports the roof folded down. The roof however is pretty well fixed by the trunk so there is no real need for that brace. My complete system is:
Headunit - Pioneer Premiere 980BT
Front - Focal 165K2P
Rear - Kenwood Excelon 4x6
Sub - Kenwood Excelon XV800F
Amp - Hertz EP5
So - this is it. I hope I covered everything. Good luck to everyone.
