Re: Supercharger, What\'s the difference between 5, 7 or 8 PSI pulley?
I think if you investigate most after market forged pistons they are NOT stock bore, they are 10,20 or 30 over. Unless you can squeeze than slightly are piston in that smaller hole, it will not work. The other reason why most respected tuners will not use the stock bore is they will clean up the cylinder bore by re cutting or cleaning the cylinder, vs honing the bore. A job done is worth doing correctly the first time vs doing twice and spending way more money.
Cudaman
Tim, pistons themselves are around $1,000, but the labor to install them is significant unless you do it yourself. The other big question is how much boost you plan to run, and whether you think you'll be happy with a basic 5-7 psi system. You could just replace the pistons and keep the costs down, but if you think you may want to crank up the boost later, while you're in there you probably should upgrade the lifters and add roller rockers and stronger pushrods as well. It would also make a lot of sense to have your heads ported (or swap them out for a ported set), and consider a cam change. And yes, any or all of the above can be done with the engine in the car by someone who is careful and knows what they're doing, although most tuners won't do it that way as they prefer to have the block bored etc.
As far as anything that changed for the worse in 2001 from a blower perspective (actually it was in 2000), the pistons are the only thing.
Cudaman
