Taller tires and Gear Ratio, help
steelskeet
Hello everyone,
I am trying to figure out my new gear ratio since I changed to 19" wheels and tires on my 02'FE.
I now have 345/30/19 vs the 335/30/18
My previous tire was a PS2 25.9" OD
New tire Hoosier R6 26.8" OD
I have a stock 3.08 rear gear ratio
25.9/26.8 * 3.08 = 2.94 new gear ratio?
Did I do this right? 2.94 I guess that should not be that noticeable?
PhoenixGTS
Phoenix Arizona
The effective difference is 0.20 of gear ratio. For example, if you have 3.73 gears in your Gen II with stock height tires, and you change to Gen III height tires your effectve ratio goes from 3.73 to 3.55. That means if you have stock 3.07 gears and go to the taller rear tires your effective ratio goes down to 2.87 or so. In other words ridiculously tall.
steelskeet
I think I will drive it this way for awhile, but maybe a set of 3.33 are in my future.
Thanks for the links they were both very useful.
wizzlepoof
