Vic
- Joined
- Nov 12, 2000
- Posts
- 6,764
- Reaction score
- 1
There is only sport shims on the front, right? When I take em out, I'll get more negative camber, which is good, but which way does the toe go, after shim removal? A search result came up with conflicting views. One guy said you end up with more toe out, the other guy thought it was more toe in. Which is it?
And to correct for a fast track like Willow Springs, would I want 1/8" toe out, or 1/4"? Probably 1/8", right? Which way to turn the tie rod? If you say CW, (or CCW), please indicate which end you are looking at to determine rotation direction. CW from one end looks like CCW from the other end! I could answer the tie rod direction question myself by looking at the threads, I guess. But I haven't yet visualized how changing the camber can affects the toe, so if anybody can clue me in...........?
Finally, What will happen to the feel and handling of the car, say, on a constant speed and radius high speed turn? Will the front bite better now, with the more negative camber? (Yes) And since it sticks better than the rear, would the back end tend to break loose first, making the car now tend to oversteer more than before?
Or maybe you just turn the wheel accordingly, to compensate? Any experiences with this set up?
