GTSnake
Texas Vipers. How do you pass the emissions testing required to renew your plates? There's no way in hell my car would pass. Please DM me for non-public solutions.
Yeah, I know there are ways to do it. That's why I asked people to DM me if they had a solution.My Viper came from Houston and the previous owner (AlexK aka SneakySnakes) got it to pass Texas Smog Test even with the Belanger exhaust.
So it can be done.
Try reaching out to him on Instagram or YouTube (not sure if he's still on UTube).
I'm in WA state, if they did away with it here...what does that tell ya. Cars have met and far exceeded emissions requirements for a very long time.The funny thing is auto test shops are complaining that there will be lots of ***** cars on the road without testing. However if you look at all the states without testing there is no such issue. It was just a huge racket to extort people of more money.
I'm pretty sure it's everything. My car doesn't have an issue with a safety test but no way will it pass emissions.I read that as a safety inspection not emissions test.
What's involved with an OBD-2 check?I thought they require passing OBD-2 check?
So you basically did what VW and FCA did to pass testing. Change the software during the test then change it back. Only difference is you didn't get penalized billions of $$$.For what its worth, I spent 2 1/2 years trying to get my Gen 3 emission approved after I had Heads, Cam, AR headers w/ HF Cats, and ECU tune done. I learned what didn't work when I put the factory exhaust headers and (4) factory cats back on. What finally made it pass was getting the ECU reset back to factory settings. In Wisconsin you had to get 3 of the 4 emission monitors to turn green on the OBD instrument check. Once I got the ECU re-flashed I got four green monitors in less than 10 miles! Since I put my (2) HF cats back on and all emissions reading still good. Also, make sure your (4) Ox sensors are working. Next step is to load the performance tune back on the ECU.
Texas region as well. The way I understand it is emissions will still be required by the counties that do, safety will not/cannot be.I'm pretty sure it's everything. My car doesn't have an issue with a safety test but no way will it pass emissions.
I just got my car inspected today, lived in Austin for 17 years, never once had an emissions test performed.All of TX has safety tests, and some spots have emissions tests as well. Looks like OP lives in Austin, which is one such spot.
Is your car showing a CEL? If it's not, you should be fine. The only emissions test is they hook up an OBD II cable and check for any codes, no codes, no problem.Yeah, I know there are ways to do it. That's why I asked people to DM me if they had a solution.
Oh, Ok, good to know. No CEL on my car. I thought I was going to need to go to one of those back alley shops....Is your car showing a CEL? If it's not, you should be fine. The only emissions test is they hook up an OBD II cable and check for any codes, no codes, no problem.
Depends on if you got a tune on it. The check is not just CEL but readiness of the systems and you can't clear codes and go get tested. You need drive cycles. If your tune has emission stuff turned off or deleted, you ain't going to pass.Oh, Ok, good to know. No CEL on my car. I thought I was going to need to go to one of those back alley shops....
