As was discssed earlier this week, there seems to be a small percentage of the fuel pump voltage boosters that set a P0505 code. That is a malfunction of the idle air control motor. The indirect source of the problem comes from feeding the booster off of the PDC. When you feed directly from the battery, the problem goes away. Here are all the answers:
1. When ytou turn on the key the fuel pump cycles for 1.3 seconds, that is exact (measured on a scope), the manual says 2 seconds.
2. At the moment the booster energizes the pump there is a 6 Meghz sine wave superimposed on the 12 vdc. The waveform lasts for 2 usec. This is what sets the IAC code in the PCM. This has to be a result of the the capacitance in the booster tuning with the inductance in the line to booster. Typically it is referred to as a tank circuit.
3. The answer is to feed the booster from a source other than the PDC. I chose to pick up the power from the starter motor post. Another possible solution would be a filter cap tuned to a frequency close to 6 Meghz.
