Thermostat Housing Question
neo_rambo
Dallas,Tx
I was watching this video regarding the Thermostat installation in a Gen II. I noticed he drilled holes in the thermostat. As anyone seen or done this before? Is it a common practice? I'm switching my Gen III thermostat with a 170.
YouTube - viper thermostat install
Viper X
Not seen this "hole drilling before".
Gen III gasket, etc. is different.
T-stat in video does not appear to be Gen III OE Cal Therm type.
I have a Cal Therm OE type 170 T-stat in my Gen III and it works very well.
Dan
intense5.5
Northern NJ
Some engines require a two stage thermostat - one that has one medium size valve and one small valve as opposed to the common single large valve type.They cure a problem common to Toyota 22re motors (I went threw it with mine,that's how I found out),but Toyota gets $30 for it.Drilling one or two 1/8" holes in a standard $5 single stage thermostat is the cheap way out and works fine.Saving money = owning a viper :2tu::headbang:.
N
neo_rambo
Dallas,Tx
Well, so if I bought a 170 degree thermostat I could drill 1/8 in the thermostat sides for my gen III to reduce the hose from crimping as much and will help the cooling of the mortor
