XLR8,
Not that I am putting a cam in my car or anything because it is bone stock, but I just purchased a Cloyes True Roller Hex-A-Just timing gear / chain set from More Performance (704-393-8241
www.MorePerformanceInc.com). Their Part number CLO 9-3152A. It was $189.00. Of note, it uses a 3 bolt gear so your cam will need to be modified for 3 bolts (Arrow will do this for $50 which includes the bolts) if it doesn't come that way. While it is apart, you should go with the three bolt set up anyways.
Hope this helps.
Regards,
