Timing curve?
jp
Umea, Sweden.
I will start the tuning of the new engine next week, I need some baseline data to be able to set the timing before we fires it up.
Does somebody have a timing curve to share?
The engine has 9.4 compression and the camshaft is 250 single pattern 116 lobe.
All information is appreciated.
Jack B
NE Ohio
If you want, I have the stock curve. What are you using for a computer.
J
jp
Umea, Sweden.
Jack, we are using the VEC-system. I have the stock numbers but only up to 5000rpm, I would like the up to 6000rpm.
But It would still be great to look at your curve, just to compare to ours.
Thank You
/JP
No members online now.
JpKL
