tire life
Great Falls, Montana USA
I get approximately 14K out of the rear tires. The fronts last about twice as long. This is normal Hwy use with some in town driving. More aggressive driving can limit the Mlg even more. If Ya wan'a play Ya got'a pay. (JD)
Here is the formula:
MPT = 16000 -(BOF 250) -(RRF 500) - (NCF 1000 Fronts only)
Where: MPT = Miles per tire; BOF = Burn Out Factor per each burnout, rears only, and RRF = Road Race Factor per all 4, and NCF = negative Camber Factor on roadraced fronts.
The result is: "What those other guys said!!" ...about 12K-15K rear, and maybe a LOT more up front unless you roadrace w/ negative camber !!!
JonB~~~:<~
Jeff-00-ACR
Spring, TX
I'm delightfully surprised so far. I have 5000 miles on my ACR and the tires are still in good shape. My 97 911 Turbo S went through rear tires every 5000 miles. They did wear evenly, right down to the cord.
Jeff
tractor1996
