Transmission Fluid for G1 & G2
jkroberts21
Alpine CA
Amsoil recommends an automatic transmission fluid for the gen 1: AMSOIL Signature Series Multi-Vehicle 100% Synthetic Automatic Transmission Fluid
I even called them to confirm
But for the gen 2: AMSOIL 75W-90 Manual Transmission & Transaxle Gear Lube
Has anyone used AMSOIL automatic transmission fluid in their gen 1?
The Gen 1s had different blocker rings in the synchros and require a Dexron III or better ATF fluid. The Gen 2s have carbon rings and can work well with GL4 multigrade synthetics for track or warm weather use.
serafins
Metro Detroit
Use a good 75w-90, just avoid GL5 rated fluids. I used anything I had on the shelf, 2qts redline GL4, 1qt BG synchroshift, 1qt auto trans fluid. Figured the auto trans fluid would add a little detergent capability to the mix and balance out the thicker synchroshift. A manual trans is very simple and will be fine as long as it’s got clean fluid and nothing that will eat internal parts like GL5
I went back to Dexron III, shifts much better now. If you get NGR, its not harmful just something you may hear.
A simple search reveals
Read sticker on tranny.
Do not use synthetic oil.
I posted this on multiple threads here and there is tons of threads about this
Monopoly
Toronto
Using Amsoil 75-90 and it says on the bottle Chrysler* MS-9070 replacement. 3000miles feels great.
steve e
On my 1999 GTS, the service manual says to use ATF +4 , so I use Amsoil multi vehicle full synthetic trans fluid that's there top of the line transmission fluid, any type of gear oil is not recommended and will make the transmission harder to shift in colder weather . Use the fluid your service manual recommends, then upgrade if you like but keep it the same type, so instead of Mopar ATF+4 I upgraded to Amsoils version of that type of fluid, owned a auto repair center for 40 years and rebuilt thousands of transmissions of all types, and taught Auto tech so your hearing this from a qualified technician.
efnfast
Canada
What is the recommended fluid for a 2002? Some sites say 75-90 GL4 (e.g., Amsoil), others say use Mopar ATF+4.
For what it's worth, I emailed Tremec and asked them the same question regarding what to use since SynTorq is out of production. They said ATF is fine. I think they recommended Mobil 1 ATF, but guessing any good quality one would work. T56s are in everything and I think the vast majority use ATF of some variety. I never knew what the neutral gear rattle (NGR) was until I put a T56 in my 67 Dart. I believe it was out of a Gen 2 and had the Dexron sticker on it, so that's what I filled it with and it's noticeable the noise it makes before you put it into gear. I think Mopar had a TSB about swapping from ATF to the SynTorq to reduce this noise, so they must be compatible to some degree. Maybe not the early cars, but would have to dig through the TSBs to see what it actually applied to to know for sure.
lane_viper
Tennessee
For what its worth I use Syncromesh MT fluid in 3 of my Manual cars, 2 T56's and the S2000.
S2000 has 197k
C5Z has 145k
Viper has 97k
I did have to do rebuilds on the T56's and used syncromesh after the rebuilds. I bought the cars used and have been running them with Sycnromesh under my ownership.
The C5z has more miles on the rebuild with Syncromesh that id did origiinally.
The viper has 10Kmiles on the rebuild.
I've owned S2k for 17years, and it has over 100K miles with Sycnromesh.
Its readily available and cheap, and has served me well with my cars.
