TommyG
I have 295/30/19 less than 200 miles ps2s up front and they are wrapped around the 19/10.5 I forged Revs from this Jan 09. The wheels look great on the car and for the 3100k I paid for a set of 19/20 I can't comlain too much. Don't know if anyone else has these wheels but the problem I have is with the valves. Sometimes just checking the air will make the little middle part get stuck and air will be spewing out until I get my key and try and tap the end of it until it seals up again. Kinda frustrating. Anyway I check all cold tires this am early before I head out for some viper therapy and get all to 29psi. I do a few spirited runs on the frontage road and hwy, it is like 7am and pretty dead on the roads. I grab a coffee and sit and admire my freshly washed car from Sat. I then head out to Boerne to scout some property for a client and then get back home, so in total maybe 1-1.5 hours of drive. I don't feel anything wierd at any time. I get out of car and notice my driver side front tire is flat. I check pressure and it is 8lbs from the 29 I set it at. I search the whole tire for a nail or anything that might show a breach. Nothing. I back the car up to further inspect and again nothing. I fill up the tire to 31.5 hot just to see how slow the leak is and try figure out how much time I was driving on a flat tire. I have a digital psi gauge and I plug it in the valve and hold it there to see if I can read the drop in psi but it holds for over a minute. I wait one hour and re check and the tire cools down and now it is like 31 and holding. I don't understand how it could have dropped 21 lbs in the course of 1-1.5 hours and now it is either holding or creeping down extremely slowly. The tire does not appear to have a ring around the side wall and I know what that looks like bc I did this last year to my Cayeene Turbo on a 20 inch wheel and a Mich Diamaris and drove it for hours not knowing it was flat and had to replace the tire. My only guess is I have a faulty valve stem or leak in tire that gets worse when the tire is spinning? The tires were on my car for a very short time 100-200 miles then I put my stock wheels with my Khumos for some drag strip and road course fun and these I forged wheels and tires sat in storage stacked for a couple of months. Prior to putting on I checked cold temp and they held well for that time at 27 psi. Any thoughts form anyone that has had this kind of occurance? Only good news is I bought the warranty from discount tire so if it was a road hazard I new I would be covered but a leak? I don't know if this is tire or wheel related?
Tom
Tom
