Turn Signals ?
Next Phase
North Carolina
My turn signals are not working.... did a search and did not find anything. Car was just delivered yesterday and I spoke to the owner and he said they were working fine when the car left.
I pushed in all the fuses to make sure and still nothing.
I assume this is a fuse issue? I also noticed that my high beams did not stay on when I hit them.... I read that this was a fuse issue also...
Thanks for any info!
:2tu:
Tom F&L GoR
Wappingers Falls
Turn signal flasher power goes through the ignition switch, then fuse #19. Headlights are powered by fuse #14, then through the headlight switch, then through fuse #3 and #4. There is also a circuit breaker in the headlight switch. One common item is the turn signal stalk/dimmer switch. Maybe the connector under the dash is loose?
Or, you need a service manual with the wiring diagram.
N
Next Phase
North Carolina
Thanks for the info... I have a friend of mine stopping by this Saturday to check it out.
The hazard lights are out as well....
N
Next Phase
North Carolina
If you want help, you have to give clues... how'd you do it?
I just bought the car and got it delivered on Monday. Turn signals didn't work when I took it out for a drive.
I took the car out today and guess what? They were working....???
N
Next Phase
North Carolina
They are working now?
Yup...they sure are....:)
Then some dickless mother ****er side swiped my car today... I don't know how they did it, but it must have been on purpose since I parked far away from everyone. I am ****in' livid right now....
Went out to breakfast with my parents this AM and then went to Home Depot. I am baffled on how it happened.... :crazy2:
Ricketts
Fayetteville NC
Oh no!!! How bad is it?
jdeft1
Metropolis
You gotta be kidding!!! It was just delivered five days ago with a ghost electrical problem then side-swiped today!?!?!
Post some pics then go buy a lotto ticket!
Sorry to hear it.... Hopefully it's not too bad.
TAILWAG
:mad: that *****!
Tom Sessions
Hampstead,NC.
What a way to start off with your viper. Call Kenny Hawkins 919-851-0242 he is on Germantown rd off of 54. Has 2 comp coupes and some other cool toys. He can fix your car right up.His body shop does a lot of high end repairs.
N
Next Phase
North Carolina
Bought 11 power ball tickets yesterday... damage was not too bad, but enough to kill my mood yesterday. I'm over it... I'm getting it detailed tomorrow and will see what kind of magic my guy can do...
Unfortunately, it took the paint off in one area pretty bad.
Took the car out for drive with my dad last night and I felt instantly better :D
N
Next Phase
North Carolina
Oh, I took the flasher module out and also took out the turn signal fuses... put them all back in and that might have done the trick.
tractor1996
