AAKVIPER
I stopped by the dealership this afternoon and inspected the motor with the heads off.
I then chatted with the Viper tech and told me he did not find no other problems.
While I was there, I examinationed the old removed gaskets and they were compromised. The coolant cut out area was cracked in four spots, and the oil galley area on # 4 cylinder looked suspect with some hairline cracks starting to appear. Only 8,500 miles on the motor.
I requested to the tech to add a new OEM thermostat and gasket set for good measure. He also started to extract the spark plugs insuring I have no cross threading and he will add some thread oil compound so when I will change the plugs years from now, all will go well.
So far all is on schedule. But I must add, all the Gen 1-2 Viper owners, this head gasket problem is a real issue. Warning to the wise..get them done. No matter what mileage you have on your Gen 1-2. I was shocked at what I found when I inspected them
Dodge dropped the ball on this component, this issue should have never had happened if they did their research correctly.
I will keep you posted, Arthur
http://forums.viperclub.org/threads...-gen-1-and-2-owners..Buhler-and-the-Cometric-
