VEC. 1 installed !!!!!
SNKEBIT
western wisc.
I just got done puttin' a vec.1 in my 94 RT. What a difference on WOT!!!!!!!!
A good deal for the money! If it gave me the 10-15 hp it feels like, it was well worth the 200 bucks!!!!!! Sounds alot nastier at wot also!!! :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang: :headbang:
PRVT JET
streamwood, il usa
without tuning mine, it gave me 3 mph in the 1/8 mile. You have to get on the dyno to get the perfect setting on your car.
STUGOTS
NY/CT
and think the vec 2 is susposto be better then that and what you saw is alot for a tuner like that.
LIVIPER
New York
How exactly does it work? Does it make HP by modifying the factory fuel/air ratio?
BigCarrot
Dallas, TX
Stu, most people see results like that from the Vec 1. I got about 20 at the wheels on a before and after dyno on the same day.
STUGOTS
NY/CT
im buying the vec 2 this weekend i will let you guys know how it turns out
V
vegasviper
Guest
Does Sean have the program available for stock engines? and are the gains as before noted of 30 to 50 RWHP?
Snakester
Morgan Hill
I didn't get such a huge response to adding my VEC-1 (13RWHP and 8RWTQ with dyno tuning). But the bigger value for me is how the VEC-1 evens out the power.
Without the VEC-1 I had some surging and hesitation at low RPMS, and afterwards it is smooth and seamless. And I can definitely feel the better power delivery, more than the numbers reveal.
-Dean.
