http://www.youtube.com/watch?feature=player_embedded&v=9SZxsSz6cCo
SRT and Team Viper, much respect on your accomplishment and a great informational Youtube video of Mr. Richard Winkles giving us some insight on the Gen V power plant! I want one in my stable now..
A few questions if possible and thanks for doing the deed!
:The new intake, would a good comparison of the improved air flow be similar to a ported Gen 4 lower intake?
:The new cam, is there more Valve lift as well as increased intake duration?
:The new aluminum flywheel, faired better than the steel unit, how? ACR-X was mention, engineers where surprised? What type of initial testing was done?
:The new exhaust, if more free flowing than Gen 4, what changes have been done, cats, mufflers ?
:Will the new Head Gaskets be retrofittable to Gen 4 and earlier generations?
:New Engine RPM capability?
:The new rear differential, has this unit been upgrade or tweaked to improve on?
Thanks!
BAD BOYZZ GARAGE, INC.
Toddy Gomez - President
=DISTRIBUTORS OF POWER=![]()
Toddy,
Thanks for the compliments!
· The Gen V intake has longer runners with an improved shape and entry. It will outperform a ported Gen IV manifold.
· Same lift, longer duration and acceleration.
· The aluminum flywheel dissipates heat better and does not require as much thermal mass.
· Exhaust changes include a single pass wash coat to the cats (for precious metal deposition) and a new resonator (see answer to post #9).
· The Gen V head gaskets will work on Gen III & Gen IV and would be a cooling improvement but there also some holes in the head that would need to be added and one that would need to be blocked.
· Fuel cut-off will remain at 6400 rpm.
· Same basic rear differential with 3.55:1 gears and new stud shafts and half shafts for improved serviceability and function.
