Was there a problem with the 1994 power steering?
Qualitywires.com
Louisville, KY
My steering is making a funny noise when I turn it to the right. Note: I'm not completely turning all the way. Maybe 50%. Doesn't always do it. Fluids are full.
Gerald
Near Tampa Bay
Adam,
HOw many times do I have to tell you about questions like these???
Simple fix... DON'T TURN RIGHT ANYMORE!!!! Make a large left hand sweeping turn. If that doesn't work, try what Antonio said, check for hidden gerbils in trunk, glove box, power steering pump.
On a serious note. The pumps are known to go bad.Mine in my '94 did.
Gerald
Quantico, VA
ab,
Not sure what the sound is you are hearing, but Ted May (my Viper tech.-stud) said I should get a power steering cooler for my GenI '94. He said getting one of those is a lot cheaper than replacing the power steering pump which will often burn up because of all the heat (power steering fluid getting too hot, etc.).
Good luck-
Rollo
Q
Qualitywires.com
Louisville, KY
Hmm..Maybe a cooler would be a good idea. How do you drain the old fluid from the rack and pump? What should I use? I bet my fluids are burnt...I doubt it has been ever changed either too..please give some advice. Thanks guys!
Q
Qualitywires.com
Louisville, KY
Gerbils? gerbils? I think antonia has 400 Gerbil power under his hood of his Viper. Any other SERIOUS reply's out there? I think the two clowns Antonia and Gerald had their fun..I think they are still laughing at their post..in fact I think they are the only ones laughing at their post. hehe! Okay serious answers shoot on! thanks in advance!
kverges
Dallas, TX USA
JonB
You are getting rusty! GenI never had P/S coolers; I burned two systems to the ground at track events. The cooler needs to be relocated to the front fascia and should be a good quality Mocal or similar, at least 11" x 3.5" x 1". That and good synthetic fluid and you should have no problems.
As far as the right v left turn noise, that's truly strange. You did not indicate whether it was a whine or another sound. I would also check for interference with suspension or body work as the wheels are turned left to right. If it is a whine, but the steering feels OK, then change fluid, add a cooler and don't sweat it. Drown out the noise with sprited application of throttle.
Keith
Puntacanaviper
