what size ccw 600 wheels to suit 97 gts ????
nismobrown
wales, GB
i am about to buy new wheels to suit a blue/white 97 gts .
please can anyone tell me the best combination from the following , a srt big brake kit or similar will also be installed at the same time.
ccw 600 19" front 19" rears
ccw 600 19" front 20" rears
ccw 600 20" front 20" rears
thanks!
N
nismobrown
wales, GB
19/20s would be nice, but being in GB might limit your choices.
thanks, i can get 345/25/20 for the rear and matching 285/30/19 for the front.
the easiest to get are toyo t1r
do you know if these are any good ?
do you think the 20" will rub the rear if the car hits bump in road or similar ?
jasontiff
Austin
The 20" in the rear won't rub with a 25 sidewall. If you went to a 30 sidewall like the PS2s you'd have rubbing issues. I had Nittos and 19/20 on my last car and loved them.
hou99gts
Rosharon, TX
18/19 SRT sizes looks the best to me if they clear your brake setup. Here they are on my GTS (the car isn't that tall, I hadn't driven the car to settle the suspension yet).
Burt G
Nor. Ca.
I'm running 19/19 Full Chrome SP600's on my "96 B/W and must say the fitment is ideal with the
Stop-Tech BBK.
Simms
Pittsburgh, PA
I run 19's all around.
DanielR
+1 for 19 at each corner, but 18 front and 19 rear looks nice also.
N
nismobrown
wales, GB
this car looks perfect with that wheel set up.
please can you tell me the following
are the front wheels 10" or 11" wide ?
if 11" do they cause stone chips to the car and if so what part of the paintwork ?
what size tires are you using ?
do you think using 20" on the rear would cause any problems?
thanks for your help, Dave.
jasontiff
Austin
These look like 20/20 to me. I loved this car.
bigmack339
Texas
19/ 20 combo looks great, but the acceleration factor is diminished. Took a custom ROE SCT Tune to fix that, but still degraded.
chiefchad
I never thought I liked solid red either 'till seeing the photo. Zoinks! I also now regret buying a third gen.
The second gens look killer.
tractor1996
