1bad,
I always expect and appreciate your comments, even if you rely on the merits of others to make your points.
As for Icing the intake, a cold air charge is no secret in racing and there are alternatives to ICE Bags, like cool blankets that can lay across the intake. I have seen them used on LPE cars.
I prefer to have ACTUAL conditions when I race, as do many of the regular folk(not superheros like you so profess)as it is difficult at best for a Viper owner to haul a cooler full of ice bags to the track in trunk.
Question..Why would someone want to run stock tire pressure knowing that the contact patch is smaller than with tires set at @ 23 psi, but want to ice down the engine for the last bit of power?? Im confused.
It is easy to run 11's on a prepped track in a stock viper. We have done it many times. The average drag strip on a Wed or Fri nite test session is not prepped and the surface is usually worse than the average street, so to profess about a magazine test bed at a sea level, closed session, prepped track with optimum conditions is not only considered bogus boasting(in my book) but it undermines the efforts of the average Viper owner who takes his car to the track on a typical tuning session. You make these guys feel like if they can't run 11.70's with their stock Viper then they ****. Give the regular drivers on regular tracks a break, please.
With that said, Ice down your intakes if you can without creating a hassle for yourself. Make sure that you do a few "dry hops" to sling the water out of the intake webbing before you get to the front of the staging lanes or when you launch water will spill all over the starting line and ruin the track surface for those folks behind you.
Don't be upset with a 12.20 in a stock viper at sea level, thats what the RECOGNIZED magazines have listed in their data base for a Gen II viper.
Again, best of luck to all, give drag racing a try, you will love it.
Tom
Http://btrviper.com
