Boxer12
Come on guys, these cars have been out there for a while so give us some real life track reports! Are you putting up some good track times?
Way too early, not enough cars out yet. I would bet the vast majority of Vipers never see the track. Not only that, no one is going to be setting blazing times in their first time out in the car.
We will be lucky if there is a good sampling of lap times by this time next year.
Idk, when I took delivery of my ACR, took it to the track that weekend for a shake down with just barely 500 miles, and there were three of us there with paper plates on the car!
Pilota, NASA events are very reasonably priced, well run and a great time. Go join them! It is prob a lot safer for your car to run in controlled groups than just with whomever shows up at your local T&T event. I think I saw on a post you have racing experience, and if you have a racing license, you can prob just join up in HPDE 3 for a check out and after one session they will prob move you to HPDE 4 (open passing). Get a TT license for an extra $10 and run with the fast boys!
I think Ole Blue would be OK in HPDE4, but I don't think the fast guys would want him in TT.
...He'd end up taking their contingency tires like he did from the NARRA guys.
In all seriousness, he is EXTREMELY fast!
Pilota, don't you want to be the first guy in the world to put some Hoosiers on one and see what she'll do? Come on! I know you want to!!
I've been looking for a reason to get out to LS...maybe I will join you out there! I would love to see it fly!!
My personal curiosity is whether it will post a better time than a nicely modded ACR.
Boxer12, I would say I'm a solid intermediate driver. Mark set up the shocks with 500/700 springs on MCS double adjustable shocks. Camber is -2.4 front and about -1.3 rear. The ride height is 4 1/4 front and 5 1/2" rear. Corner weights are 837/832 front and 812/792 rear. The car handles well except on high speed sweepers (100mph+) where the front bobs up and down and side to side, at the same time. Understeer is more prevalent than oversteer. I've tried many combinations of compression and rebound settings and tire pressures. The car has corsa's installed. I've got about 200 track miles and the right front is shredded - mainly from a fast left sweeper. I think I need more camber and higher spring rates which I hope to test next week. For pictures see Mark's web site. Any advice is appreciated. Allan
Allen, I am sure Mark adjusted the bump steer after shock change? Also, is the front tire wearing more on the inside or outside shoulder? Personally I would start with less camber all around (try the settings I suggested above), check the bump steer, and see if you can 'neutralize' the handling a little. Mark may have checked with SRT on preferred track settings and those were recommended, but SRT doesn't test with MCS. To ease the bobbing, add some clicks to the rebound setting up front. (I don't know how many clicks since I'm not familiar with the MCS dampers). Too much camber can make it tricky in high speed situations, whether its a sweeper or a straight. I think a lot of drivers use too much camber trying to improve handling when you can adjust the shocks to ease the handling in most situations.
Thanks for all the suggestions Guy's. The spring rates are 500/800, corner weights are with 1/8 tank of fuel and no driver, I don't know about bump steer,tire wear is greatest on the inside of all tires and right-front is shredded on the outside I have the car at TopSpeed Motorsports here in Alpharetta Ga. They have a lot of "sedan" race experience - including 4 strait overall wins in The One Lap of America. I 'll let you all know what they say. Thanks again, Allan
