Fast Freddy
I HAVE A 2001 VIPER ACR(ABS EQUIPPED) THAT HAD 63 MILES ON IT WHEN I BOUGHT IT. I DROVE APPROXIMATELY 1000 MILES ON IT TO BREAK EVERYTHING IN. AT THE 250 MILE MARK I CHANGED OIL & FILTER TO PENZOIL 10-40 [NON-SYNTHETIC) WEIGHT. AT 1250 MILE MARK I CHANGED OIL & FILTER TO CASTROL 5-50 WEIGHT FULLY SYNTHETIC AND USED A K&N PERFORMANCE GOLD OIL FILTER. ANY WAY, AT ABOUT THE 600 MILE MARK I STARTED REVVING ENGINE RPM'S TO ABOUT 4000-4500 RPM DURING GEAR SHIFTS TO GET A FINAL PISTON-RING SEAT ON MOTOR, AND STARTED DOING SOME FAIRLY AGGRESSIVE BRAKING TO GET A FINAL SEAT IN ON MY BRAKE PADS AND ROTORS. IT WAS AT THIS TIME WHEN I FIRST NOTICED THIS RECURRING PROBLEM THAT I AM HAVING "WHITE SMOKE FROM BACK OF CAR". THIS ONLY HAPPENS WHEN I DO A MINIMUM OF 4-5 HIGH SPEED(80 MPH) BRAKE STOPS IN A ROW. THEN AFTER THIS PROCESS WHEN I AM STOPPED AND THE MOTOR IS IDLING THERE IS NO WHITE SMOKE BUT IF I REV UP THE MOTOR 4500-5000 RPM'S I WILL SEE LOTS OF WHITE SMOKE. OR IF I TAKE OFF RIGHT AWAY AFTER STOPPING I WILL SEE BIG CLOUD OF WHITE SMOKE. I NOW HAVE 2000 MILES ON THE CAR AND THIS PROBLEM WILL STILL OCCUR WHENEVER I SIMULATE THIS DRIVING TECHNIQUE, BUT NOT AT ANY OTHER TIME. THIS HAS TO BE OIL BLOW-BY FROM THE PISTON RINGS. IS IT POSSIBLE THAT THE OIL PUMP IS GETTING STARVED(OIL PAN SLOSH) FROM HIGH G-LOADS UNDER HARD BRAKING? IF SO ANY BODY ROADRACING THESE CARS MUST BE EXPERIENCING THIS PROBLEM. IF SO LET ME KNOW SOLUTION(BAFFLED OIL PAN)ETC. I RUN 10 QUARTS OF OIL. ALSO HOW DO I APPROACH MY DODGE DEALER TO SOLVE THIS PROBLEM? I KNOW THE CAR IS UNDER WARRANTY BUT THE ONLY WAY IT WILL EXHBIT THIS SYMPTOM IS UNDER THE PREVIOUSLY STATED SCENARIO. I GUESS I WILL JUST HAVE TO TAKE THEM OUT FOR THE RIDE OF THEIR LIFE. LOL!!!!
