Who's Chemically Cooling their Paxton blower
VIPER D
dutchess county, ny
Who\'s Chemically Cooling their Paxton blower
Just wanted to know who is running the roe racing or snow performance ****/water injection and what kind of gains (hp or temp charge) can be expected. Also who uses a vec 2 with one of these bad boys.
thanks in advance
vd..
Sleeper
Saint Louis, MO
Re: Who\'s Chemically Cooling their Paxton blower
Mine had a wetter in it. ;)
Hold on BC, your diaper is off-topic for the moment.
Dmitry, no water **** here, but I am using VEC2 to manage larger injectors with a supercharger. What are you using the VEC2 for? Are you using a Split Sec. FMU?
The VEC2 requires some tuning, but has good potential.
TD
VIPER D
dutchess county, ny
Thomas
I am using the splitsec to just turn on and off the pumps. B/C I have a cust exhaust and no cats I needed extra fuel it was a lean so I use the vec 2 for timimng and injector pulse. I also modded my vec2 to to be used for a ****/water injection trigger and shift light at the same time.
vd..
Dave T (BADVENM)
Goodland, KS
Not sure if you have looked on SRT10forum.com but a guy over there is claiming to have solved the heat soak issue. He did 3 dyno runs back to back to back, the third one matching performance numbers of the first on a non tuned Ram SRT.
Of course he's not giving away his secret and I could not verify his claim but if true shows some promise.
Sleeper
Saint Louis, MO
Yes, after exhaust modifications I also went to the VEC2 to avoid lean conditions. At the same time we installed 43 lb. injectors, along with an MSD voltage booster for the stock fuel pump. I won't be seeing lean conditions anytime soon. I am interested in intergrating the Wideband Commander with the VEC2.I just need to find a place for the gauges, and may end up with windshield mount like you have. My splitsec also runs the accessory fuel pumps.
Regarding the water/methanol ViperD, are you doing this purely as a power mod, or are you seeing excessive engine temps that concern you?
TD
VIPER D
dutchess county, ny
I also own a cobra svt that is getting a tt installed so i read alot of mustang mags in one mag they gained like 80rwhp with the ****/water injection. I want to run a little more boost like 10-11lbs and think i can get away with it. B/c of a really good tune and i have a really good wideband with wireless data loggong.
vd..
Viper X
One guy here locally is running water / **** injection. I will probably go there shortly. His is triggered by vacuum.
If you have or come up with a good water injection set-up, please let me know where I can get one.
Just installed the Autoform vented "comp coupe" style hood. Dropped about 15 - 20 degrees on the temp gage. This was on a 90 degree day, cruising at 80 - 85 mph in sixth. Good mod that should help the car live at the track.
It is amazing how much heat poors out of these big center vents while sitting at a stop light in the summer.
womsterr
That guy is from the SRT Forum is Gary from X-Metal Engineering. The same guy from which I got my Accusump.
He actually is doing a full build up for me right now with a polished crank, h-rods, forged pistons, polish and port etc...
I've seen the dyno numbers and yes, they are the real deal. If fact I spent the weekend at the Mopar Nats with Gary and the National Sales Mgr for Paxton. Paxton is REALLY impressed with what they've done. He's put a lot of R&D into solving any shortfalls with the kit and has come up with an incredible solution.
DocAdam
San Diego, CA
I used to run a water methanol setup on my SC 350Z. I ran a http://www.coolingmist.com/ single stage setup with a pressure switch triggering the injectors at 4psi.
It allowed me to run a higher psi along with an extra measure of safety. I used washer fluid (which just happens to be 10% methanol) and gives the extra benefit of having a low washer fluid warning light.
The main reason I used it was for extra cooling. It made a huge difference, especially in the summer.
DocAdam
San Diego, CA
I installed the injectors about 2 inches in front of the throttle body.
Viper X
Hey ViperD,
The hood I bought is at the paint shop, but FYI, its the Autoform hood with the center vents punched out pictured here a week or two ago.
DocAdam,
Thanks for the link. Just talked to David at coolingmist and ordered his setup. Sounds like a knowledgeable young man who is also a car guy.
It should be in later this week. I'll install it and let you know. Track event this weekend in 95 + heat. Wish I'd had it installed now.
Dan
DocAdam
San Diego, CA
Dan,
Sounds great, the main reason I went with coolingmist rather than Snow was the customer support. The system can be designed to fit just about any application and they will custom design a system for no extra charge. They were great to deal with.
For my application, there were times when I would actually get below ambient temps, you just can't do that with an intercooler alone. I also know a guy with a MR2 custom turbo setup that uses cooling mist and has run consistent 1/4 mile times on 100 degree days, back to back.
Best of luck and I look forward to hearing how it turns out.
Autoformsteve
Holland, Mi
Viper D, here is the picture of the new hood. We should have pictures of another color soon.
Tony
Autoform
Gerald
Near Tampa Bay
MAN THAT LOOKS NICE>..... A little reworking of the splitter is in order, IMO..
I've found splitters made my GenII run about 30-40 degrees hotter once it got to operating temperature. I couldn't figure out why I was almost overheating. I ripped my AF splitter off and it stays UNDER 190 Degrees, even though my car is supercharged.. ;)
G
ViperGear
