will gen3 valve covers fit a gen 1
mrbob
davenport iowa
i like the looks , just need to know if they will fit gen 1 with harlann sharp rockers , thanks to all
GTS-R 001
California (north)
Probably not with HArland sharps, you will need a spacer or they won't clear,
There are some new valve covers coming out soon
GTS-R 001
California (north)
final product pics
Will fit Gen 1, 2 or 3 perfectly, adds 1.25 inches of rocker clearance. Just don't now if there is a market for big tall valve covers that can
be painted, powder coated, polished, chromed etc.
rpm9000
Texas City, Tx.
I have found that you run into a problem trying to put taller valve covers on a gen 1. On the passenger side the throttle cable bracket sticks out over the valve cover and there is not enough clearance to install the valve cover. I tried to put a spacer under my stock valve covers and ran into this problem.
ROIII
