Thanks guys. Ive done a fair amount of searching regarding this subject. The consensus is that the stock rotors are a safer and more durable rotor than many of the lower (and perhaps mid-cost) items offered on e-bay. This including several of the 1 piece cross drilled and slotted rotors with elaborate coatings. I assumed by this there was something exceptional with the stock rotors and presumed expensive to buy new.
To me it seems there are only two ways to do brakes. Do it big with two-piece rotors (and expect to shell out at least 800.00) or stick with dialed-in stock with good pads that seem adequate even for the occasional entry level club racer burning laps once in awhile. Anything in-between misses the point of having this car in the first place. Seeing as I have bigger fish to fry, dialed-in stock appears to be the appropriate direction at this point in time.
If above is true, is it safe to assume that the stock rotors are equal in durability and function as what can be bought at napa and would be safe for an entry level club racer that may see the track twice a year? If so, thats friggin great news. If not, all I want to do is get something on there thats safe until I can step up appropriatly.
Reminder: this thread began as a 'used rotor' want-ad?
Safety is in the eye of the inspector. If you faithfully inspect your rotors before every event, buy cheap. Buy rotor-friendly pads. Change your own? The dollars-per-mile will be your reward, if that is your goal. If you scrimp on COST dont scrimp on INSPECTIONS.
If faster
lap times are your reward, buy the lightest rotor you can afford, slotted. And aggressive, high-friction rotor-eater pads. SS lines, hi-temp fluid, cooling ducts etc.
If
**** is your goal, there is a place for you, too. 2pc, colors, plating, slots and holes and assymetrical vanes and sparkle-paint if you want it. A few FAST rotors are ****!
Lastly: MoPar builds NO parts. Since D-C times and now, the LOWEST, Lowly cheap BIDDER WINS. MoPar OE rotors of Gen 1-2 era (pre 2002) almost certainly possessed better metallurgy than OE Brembo rotors of today, save for ACR. What's past, is, well..............past.
