Much longer in fact. I think it too me over two hours to get mine done. It is incredibly hard to get your hand where it needs to be to release the upper clip. I finally removed the inner fender fasteners with the exception of the 2 outer rivets so I could reach the top of the filter through the fender well. When I thought I was all done and fired up the car, the top clip let go and I had to do it all over again. So, when you think you are all done, before you put the tire back on and set the car back on the ground, turn on the key to energize the pump to make sure the clips are truly seated.
Be prepared to get gassed.
