pugads651
delete the cats and run o2 simulators problem solved.
Thanks Dan. I called back to tell you they were still there, but not the Asst Mgr who I had dealt with. Overall Service Mgr was there and said "I know nothing" about it.
Car was completely dead (from sitting) which means they must not have addressed the BCM as I asked them to about 10 times. I am supposed to get a call in the AM. I told them everything you said about an order or protocol for checking things. Parts should have LONG been there by now already (9 days). Serv Mgr told me he once waited on a headliner for 3 months and laughed. I said I CANNOT wait forever ... and for a fix that may or may not be appropriate ... or a cure.
Maroone of Coconut Creek (greater Ft Laud), FL. They have a decent reputation ... and have been ok to me at other dealership. Seemed more apathy than contrived or purposeful. Still I've had enough with it sitting there.
Is there not a recourse for me to tell them to bypass cats or something to get car running right again and give back to me ... at least until other parts come in? Or so they can diagnose it properly by seeing if that fixes it. I am afraid they will leave me hanging for WAY MORE TIME ... and now it will not start (of course), because I told them countless times it kills the battery within a couple days as it did another brand new battery (BCM ... BCM).
I think I have the right to DEMAND they do something like that to it ... AND TODAY ... to see if there is another fuel issue like the pump, or an injector leaking, etc. Then, that can be addressed and they can also replace the BCM and let me have my car back - HELP.
Ron
Thanks Dan. I assumed much of what you just said (like that they would not by-pass the cats. I did not know they were so anal about the BCM's but ... ok.
Can they not give me a new battery because of the problem though (it has already cost me out-of-pocket for the other one I replaced, it should not twice ... and because of their protocol)?
I will keep it from dying by "driving it" (which I DO ... but cannot presently ... because it is sitting there). IE - they are worsening my problems.
Thanks again, sorry for so much "wind".
Got car back and they replaced multi-function switch ... now no turn signals or flashers.
Anyone have a suggestion?
Thanks.
They fixed other issues and replaced that (multi-function wand) because they said that it was shorting. It DID leave the interior light on unless you turned it entirely off so ...
They also said turn signal switch itself was shorting (I saw on the R.O. after I left) and that it also was replaced (I thought it was a part of the multi-wand).
They also said they replaced the PCM - Powertrain Control Module and said that was shorting out too.
... but now I have no turn signals nor flashers.
Any chance it is a fuse or something relatively simple I can find and resolve?
Easiest way to access and/or remove the stalk (multi-purpose lever) ... to check the wiring and/or connections?
Through the cover? ... (there are a couple holes coming from bottom ... what type of screw head/size)?
Anything is appreciated, just do not want to mess up something that is already not working as I have never taken one of these off before.
Took whole switch out. I did not know it was a unibody switch (meaning for other side of column too). Incredibly simple (2 screws).
Checked every wire to both connection boards that go to it (both sides' boards) and all are fine.
Must be the switch (the one that they JUST replaced).
They said I HAVE to bring it back over to have it diagnosed and that, even if it is the switch AGAIN, that no one has anywhere local and will be 3-5 days to get one ... at which time I will have to go back AGAIN. UGH.
Anyone with thoughts on whether or not switch is bad "out of the box" ... and ONLY the signals and flashers (wipers/lights, etc work).
They just told me they found the relay on the old one (they forgot to attach it to this new unit).
They were very gracious and apologized which I appreciate.
Will let you know if fixes but I assume will.
