Tomer
Hmmmm...I can't speak from experience, but me thinks on a good track with good street tires even you should not be able to break the rear loose so easy (with stock range HP)...Especially granny shifting...
Do you think so, or is this a common problem?...I do have a Gen I, 96 with 415 hp...But based on some practice (although now that I think about it, my smoothest fwy on ramp is quite steep up hill - probably not realistic test due to weight transfer) but I get rubber in 2nd and 3rd, but just a small chirp....
What rear tires are you running?...ALso, most folks drop rear tire pressure which may help alot for you
Now I will stand aside and let those with experience chime in!
Tomer
Tomer
