Good afternoon!
Gonna try to keep it short but provide as much info as I can.
I was just recently passed down a 1994 RT 10. Car just has over 20,000 miles on it. It has rarely been driven and it’s spent most of its time sitting in the garage covered.
Before it was passed down to me, the very first owner (i’m 3rd) had a viper 600HF aftermarket alarm system installed. Pretty much in the years sitting the car was consistently jumped and just ran around the block or two and evidently sat long periods of times. 2nd owner went through like 4 battery replacements.
The alarm kept draining it so I’m in the process of removing the aftermarket one entirely so I don’t gotta deal with the extra BS. There used to be two key fobs, one for the factory alarm and one for the aftermarket alarm. I only have the factory alarm key fob and no longer have the aftermarket one.
With the battery replacements in past there has been no issues with putting a new one in and starting it. You could always here the fuel pump “Whine” for a couple seconds after ignition.
Since losing the aftermarket key fob, and trying to start with new battery, It’ll crank and crank but no fuel pump whine. (Probably cause no fuel pump = no fuel) I suspect who installed the alarm wired it in such to shut off fuel pump when alarm is armed. There is a valet button in which i’ve tried to go through the motions of pushing which disabled alarm but still no prime.
What i’ve checked / tried:
Made sure battery cables seated properly and little red line to positive is in tact
Pulled fuse aftermarket alarm (fuse wasn’t in it before and don’t know the amp rating of the slot)
Put a fuse in to hear aftermarket alarm barley “whirl” (sounds like the loud crazy horn with the viper system it’s on it’s last breath because it’s very quiet and staticky ) after i hit valet button to disable
Checked relay in truck wires going across trunk top portion center and hear the relay click 1 time when ignition is on.
That’s all i’ve done (pretty much all i’d know to check so far by looking at forums)
Any recommendations? Thanks!
