ILLSMOQ
I can't believe you guys put 2002 gts acr in a position to say he was right. How could this happen? If his ego wasn't big enough already.
jeez...I know But look, that part was designed as a bandaid for a problem that should not have existed in the first place. It was designed to be put into place after the whole supercharger kit is installed in the vehicle and there really isn't much room in that location to begin with. The part worked as advertised, and Doug said he'll replace the part if there is a problem. You get what yo pay for and this part didn't cost much
The real fix would be to go to a wider pully system with more belt wrap around the pullies (doug has this as well but it isn't cheap) or put more tension on the existing belt with a stronger tensioner or clock the existing one (more tension runs the risk of putting too much pressure on other components)
So I'll take the risk and I clocked the tensionor last night. I'll test it out later today if I have time...tomorrow for sure
