Good day, my 97 gts sits (inside) for long times as I work offshore. Last time home it would not start, has fuel, bought brand new Die-hard and cranks strongly. No evidence of spark. removed and cleaned fuses and as many relays as I could find. Tried resetting alarm multiple times including triggering horn and disconnecting the main battery overnight . At one point the dash alarm activation light was flashing when was cranking thus suspect the alarm somehow may be the problem but that condition was not always observed. Otherwise the key seems to arms and disarms as per normal. No other unusual displays on the dash. I note the car has been frequently jump started using the jumper terminal near the engine with a charger because of low battery but try to carefully follow the Pos/Neg connection procedure to avoid any power surges. Any ideas as the next step is to get it towed to Dodge. thanks glenng
