1998 gts owner step in!. . I just got my viper a week ago and it didnt come with an owners manual (already purchased one should be in mail) so i did some researching and searched on this forum and found out that it takes 8.5 quarts of oil. Soi did the oil/filter change, everything went smooth and i started adding oil. I figured I would put 8 quarts in then check, add, check, add . . after I put the 8 quarts in and checked he dipstick it seems over/high ?? the dipstick says low / 2 qrts / max. with only 8 quarts its alittle over the 2qrt line and in MAX is this normal? should i add another half quart? where should it be?. . I dont wanna start the car till i either add or drain the oil. Kinda alittle uptight right now any help is really appreciated. Thanks!
