SVS Turbo
SVS has built a handful of Viper V10 engines with C.O.P. (coil on plug) ignition systems. We have also made our own sparkplug wires for all of these systems. When tuning, testing or racing we’re removing wires to check and/or change sparkplugs as necessary. We try to be cautious but, there is too many times where our spark plug wires have pulled apart at the connectors. This always ends up costing us time and money repairing these wires.
I’ve heard about AB wires for some time and finally contacted Adam to make us some custom sparkplug wires for our C.O.P applications. Adam was great to deal with and went on and above to help us. When we received our new AB custom spark plug wires it was immediately evident to everyone that these wires were high quality and exactly what we needed. After using them for a while they have proven themselves as a superior product that everyone in our shop has praised.
We bench tested the AB custom C.O.P. spark plug wires with an Ohm meter and found all of them consistent while the wires we had made in house were inconsistent. The AB wires are built tough with an attention to detail. They’re heat shielded and made strong at the connectors where it’s most important.
After using many brands of spark plug wires over the years SVS has unanimously decided that they will only use and recommend AB wires for all customers engines.
Thank you AB wires for making an awesome product!
Ron Misjak Jr
SVS
Coil on plug wires made in house at SVS:
AB Custom Wires made for SVS coil on plug ignition system:
AB Custom Wires are the highest quality spark plug wires SVS has installed in the 15 years we’ve worked on Vipers.
SVS recommends AB wires for ALL Vipers!
Thanks Adam
Ron Misjak Jr
SVS
Thanks Adam
