And while we're on the subject, X pipes or H pipes in the last foot of exhaust aren't going to do anything for power. What part of 25hp for about $80 don't you understand???
Well Richard, read my post again about the effect of the crossover effect in the rear of a Viper. it said: "no power benefit, sound only. It's just too far downstream in the exhaust."
I try to give accurate info to Viper owners and don’t usually go directly at something. Sometimes, though, items come along that defy common sense to an extensive degree. Before anyone goes out and has their favorite exhaust fabricator build something like that thing, consider the theory and reasons for a balance pipe so you make an informed decision on more than one, single claim of power increase. Some claims that come up on the internet just have to be thought through and not taken as pure fact.
[*] #1: Exhaust theory 101: Power gains from exhaust can come from increasing the velocity. “The reason an X-Pipe crossover works better than an H-pipe crossover isn't more flow because of volume, but more effective use of exhaust gas velocity, How And Why "X"-Pipes Work
By Bruce Wayne, MagnaFlow Performance.” This device does nothing to help velocity, which is a primary reason balance devices are used for increasing power. In fact, it will lower exhaust temps (not what you want at that point in the system) and could very well increase backpressure and impair the flow.
[*]#2: Exhaust theory 201: Just placing a balance pipe after the collector is no guarantee that power will increase especially if the pipe is 6 feet long. While 25 hp increases from proper “H” pipes may occur, this is far from a design that is far, far from “proper”. For an increase in power there has to be an increase in scavage and velocity. It’s bringing the pulses together in one area. Funny thing, the Exhaust tuners, the pros, the racers, have found that shortening the distance between the exhausts to make the a combined unit is superior. That is why conclusions are that “X” pipes are better than “H”. Wait, here’s articles that actually measures an “H” pipe and then shortens it to become an “X” pipe and guess what? The shorter “X” pipe showed more power.
http://www.magnaflow.com/05news/magazine/05racepgs.htm and
http://www.carcraft.com/techarticles/69238/ And now there is ProChamber
http://www.rpmoutlet.com/03cobramac.htm that claims to make the “H” and “X” obsolete. But it’s also very short. In simple terms, the balance tube should be very short, or even merge both sides of the exhaust. The longer the pipe, the more bends in the pipe, and the velocity slows as the exhaust is looking for the path of least resistance.
[*]#3: No theory here (just what do racers use?). I tend to believe that if there were 25 hp by placing a balance pipe of any size, anywhere in the exhaust system the GTS-R cars would have had one and other tuners would be all over it. Nascar has been onto these balance pipes for years. They keep ‘em short.
[*]#4: Team Viper said: Viper Magazine Tech Notes Winter 2000. Herb Helbig noted that they tried a balance pipe on a dyno and saw,
"little or no improvement".
Funny thing, these odd fire V-10 motors.
[*]#5: No data to show this big, long pipe anything. Sorry, but I’ve seen 1320' times go up and down for lots of reasons. What was the mph data on those runs? A less powerful car that hooks up can turn a quicker time than a higher power car that has traction issues. Maybe that’s what happened. How about a dyno test with block off plates on and then dyno test with the tube on? No? I Didn’t think so.
[*] #6: The trend has been to shorten these balance pipes. Dr. Gas, Bassani, MagnaFlow, B&B, and the list goes on. Perhaps you can patent this design and sell it to one of them. If you have a design that can increase hp by 25 for $80 you have taken the “bang for the buck” title away from the smooth tubes and filters.
So let’s see, this design of a L-O-N-G balance pipe goes against theory and reason, isn’t supported by the pro racers or exhaust tuners, or design engineers, but you claim 25 cheap hp. Maybe you have discovered something they have all missed. Get a patent and sell it. Quick.
Reduce exhaust restriction and gain power. Headers getting a +25 I can believe, but this tube? Well, no. But I don’t have a Tornado on my car either.
http://www.vetteweb.com/tech/0307vet_xpipe/
http://www.performanceexhaust.com/moreinfo.html
I do like your FE, Though.
