>There is so much wrong info in this post about AC I don't know where to start.<
This came from you before I said anything. Then you brought up death kits. So I researched and asked questions about product labeling and Dodge repair procedures. (You know, stuff that was on the topic.) And I apologized for not looking at the reference site. Where's the "dis"?
If you have some knowledge, please share it (not just "look here") and then expect some questions. I'd rather hear it from you than sift through Google.
I brought up 'death kits' and 'sealers' because most 'ac recharge kits' include R134A which contains sealers. The sealer works by hardening when it contacts air(which is introduced into the system by the leak point). Great, it seals the leak, but it will also seal any other small 'holes' in the system(orfice tube, thermal expansion valve, condensor, etc). When those small, but vital passages get clogged, you will often run into problems. Then when you bring it to a qualified tech with a sealant identifier, and he realizes there is sealer in the system which may clog up his AC equipment, he will refuse to work on it in most cases. This is where terms such as 'death kits' come from.
AC systems are charged by weight of the refrigerant, not the pressure. Checking the pressures is just a diagnostic tool. Somewhat similar to filling your radiator...which you fill by voulume, not pressure. Not a great comparison, but you get the idea. Servicing by low pressure(which the death kits tell you to do) is very inaccurate because the low pressure side is the 'suction' side of the compressor, which means it is the liquid being returned to the compressor for compression, to start the AC cycle again. The only pressure that will get you into the ballpark on properly servicing is the high side pressure, which should be roughly 2.2 to 2.4x the ambient temp. Again, this is just a ballpark since all systems operate at slightly diffrent pressures.
As someone stated before, a empty system must be charged into a vaccum, as for one 'evacuating' the system will boil off all moisture, and also the system cannot have air in it.
As for the repair manual, it is correct about charging until the glass is clear, but it does indicate that you need to add another 8oz, which can only be done correctly with a service machine or a charging scale.
Hope this helps,
Travis
