-> My stock radiator weighs 20.2 pounds
-> My Ron Davis weighed 17.4 pounds but held one quart more fluid so that's a wash
-> My 3-core copper weighs 29 pounds. I did not measure the increased fluid capacity.
-> I never weighed my Roe 3-pass which when that epoxied thang comes back out of the car and gets compressed to the size of a shoe box by construction equipment, maybe I'll weigh it then.
When I did my triple fan installation I started collecting real data on the cooling system performance. More in relation to the stock fan versus the 3 fans, but all of that data will transfer to doing a side by side comparison to another radiator. I have the 3-core copper and the Alan's to play with next. All the 3 fan data was with the Roe. Too bad the epoxy patch didn't last.
So I'm in the same boat as Chuck now. Not much performance info on the 3-core copper. I will point out however that I did have it in the car for a while and it even developed a small leak near the inlet nozzle in the core. I took it back to the shop that build it and he repaired it with solder. Glad to see he didn't get the JB Weld 2-part epoxy out LOL. Anyway, I will work with it again soon. I add about 1/4 gallon of water a day to keep up with what the Roe is puking. Looking forward to just checking the oil when the hood is up like normal folk do. Maybe wiping the dust off the valve covers. NOT filling the cooling system every other day.
Probably even more important than the previous rant are what I believe to be a couple of important misconceptions about radiator size and performance. First off, performance...
Only an idiot like me in chemical engineering would take a perfectly good radiator out to study the effect of heat transfer of a different radiator. Most people take it out because it leaks or won't cool, and when they put in that shiny new (insert fav brand here) unit, they are like WOW, THIS NEW RADIATOR IS GREAT!!! No, more than likely it's not that your new radiator is great, it's that your old one was clogged. See the pic of my '01 factory core after ~35K miles.
Moral of that story is, ANY radiator would fix your problem. Even just getting the crap out of your old stock one on a new stock one.
The other misconception I have is about size. You'll put that new 3-pass or 3-core or whatever in and say that the bigger radiator solved your cooling problems. See the above...
What happened may have likely been you now have flow and before you didn't.
I have spent a good deal of time in my 110 degree playground watching the effect of airflow on coolant temp. And I've discovered that a bigger radiator really does not cool any better unless you get more air flowing on it. Easy to do on the highway, but I do a lot of city driving and that's when I decide the 3 fan setup would move the bar on my cooling system. It worked. More airflow is KING.
In summary of that, I would never discourage anyone as I have done myself, to get the bigger radiator, but don't blame the post installation effect of better cooling entirely on the new one. And don't expect to get the full capability of it's cooling without adding additional fans. I do have the data to show they work.
