Been to the scales?
Y2K10 SRT#39
Olympia, WA, USA
On the way back from Dyno Day last weekend, I had a chance to run over one of the WA DOT scales (scales were closed, but the machine was still working).
With me (at 225 lbs) in the car and a 1/2 tank of gas, I was surprised at the findings.
Total weight- (all 4 wheels on the scale) 3620 lbs
Front weight- 1760
Rear weight - 1880
Just more trivia I had not seen yet.
GR8_ASP
I think that is pretty close to what we have heard. BUt which is correct: 3640 or 3620? If it is 3620 then the weight would be about 3345 lb (w/o driver and fuel). I just guessed 50 lb for fuel.
Y
Y2K10 SRT#39
Olympia, WA, USA
Ya have to remember these are Washington State Scales, good only to the nearest 20 lbs or so...
What I found of interest was the balance, front to rear!!!!
GR8_ASP
Michael, I know this is rocket science but Paul stated he was 225 lb. No math required! Now, what did you calculate?
Y2K5SRT
Overland Park, KS
Gasoline weighs 5.6 pounds per gallon. The SRT has an 18.5 gallon capacity. So, let's assume the gauge is perfectly accurate (it ain't):
In Paul's case, his fuel weighed 51.8 pounds
In Keith's, his fuel weighed 64.75 pounds
Using the information provided, this means Paul's car weighs 3,343 and Keith's weighs 3,320. Geez, why am I on this thread? ;)
Chris
I think your fuel S.G. is a bit on the light side. Must be a lot of ethanol in your fuel. 6.1#/gal is much closer. Multiply water (8.3 #/gal) times around 0.72-0.74 and you're there.
GR8_ASP
Darn, my guess for Paul's fuel weight was 1.8 lb less than your calculation. We'll, back to school.
And why am I on this thread? Simple. The basketball game is during a timeout.
Y2K5SRT
Overland Park, KS
Thankfully, I have no training in fuel weights. I just searched for it and found what seemed reasonable here:
http://www.rvbg.com/weight.cfm
Gallon of water: 8.3 pounds
Gallon of liquid propane: 4.2 pounds
Gallon of gasoline: 5.6 pounds
Gallon of diesel fuel: 6.8 pounds
And as to that basketball game... :( :( :( :( :( :( :(
Chris
GR8_ASP
Agree with the basketball game. I lived in Lawrence for 4 years as a child. My dad is an alumni of KU so I know who he was rooting for.
tractor1996
