Catching up here...
Diesel oils *all* come with the extra goodies because they *all* have to meet the API "C" series of tests. And you'll see that they also all meet the API "S" categories also. Diesel oils would be an upgrade in engine oil protection in any case.
My background is engine oil formulating, both gasoline and diesel, for the US, South American, and a little of the European market. I'm a believer in the additives - they provide the performance, and that base oils are the commodity. Unless you're starting the car at sub zero temps, or going to run flat out, uphill, towing a trailer, with the oil cooler covered up, I don't see a long term advantage with synthetics, given reasonable oil drains.
I use whatever diesel oil is available at Walmart, typically Rotella T, sometimes Chevron Delo, a few times I've seen Delvac 1300. It's not a brand thing, since the step up to diesel is huge, any difference between brands in a Viper application is never going to be noticed. Mineral oil comes in 15W40. I shoot for 4000 mile drains, happy if I do it before 4500, will do it before 5000 miles.
Synthetic diesel formulations come in 5W40, which I think is a very good all around viscosity grade. Unfortunately, the -40 part doesn't allow this viscosity grade to participate in the passenger engine oil tests (would not meet the fuel economy requirements the OEMs have) and so it's never going to show up on the recommended oil lists.
