Bolt
Every time I drive my car and park it in my garage it smells like tire rubber. I got use to this and figured it was the tires. I also have been having a battery problem over the last year. This past weekend I removed my auxiliary battery connection. This connection goes directly from the alternator to the battery. The battery connector end is discolored. This is not good. More investigation was done. I noticed if I run my radio I have a main draw of power and the 140 amp alternator is not enough to keep up with the demand of the draw. Once I figured this out I took my car for a long drive and did not use the radio. Parked it in my garage and no rubber smell. Now I’m scared. Is my wiring getting that hot to where it’s melting? Fire???? Woowoooo…. What should I do? Pull fuses till I get this fixed? Replace the stock radio system with a new system? Have anyone ever heard of this or do you have any suggestions?
Bolt
Bolt
