Installing a set of powder coated calipers and SS line. What type of thread locker if any should be used on the bleeder valves. As pointed out in PM not really thread lock. I only ask because it appears the speed bleeders have some sort of red compound on them when viewed online. These are the valves that were previously installed in the calipers. Should I replace the old bleeder valves, are these parts that are stocked at most AP stores.
I went to the local parts house for crush washers assuming they would stock these in various sizes. The guy had to rob crush washers from lines that he had in stock. From what I can tell there are varying sizes on the washers. The bolts appear to be 10MM and the new washers appear to have the same OD/ID although they look a little thick. I'm assuming this is because the old ones were well crushed slightly. Should I be concerned about these and buy/order ones that I know are exact, if so what size should I be hunting down.
Thanks everyone.
Thanks everyone.
