Can my 99 R/T 10 be lowered?
TOOOFST
Barrington,il
Thought I heard,lowering the car 1" in a simple shock adjustment,or such.Looked but couldn't see how.If so do u race guru's recommend it,thanks.Closest thing to cheating,is driving a viper!She love u long time!!
Brad Manhattan Beach
Southern California
You have to buy adjustable perches to be able to lower it without buying new springs. Call Jon B at Parts Rack or a local dealer. They are included with the ACR package.
Be careful if you have steep driveways and dips in your neighborhood.
Jack B
NE Ohio
A point of interest, I put a set of Purner 18" wheels and a 30 profile tire on a Gen I. The car ended up approximately 1" lower in the front.
Jay Herbert
Sunnyvale, CA
Northwind Engineering (..... http://www.viperclub.org/northwind/ ) also sells a nifty adjustable perch, likely a lot cheaper than the ACR version:
RIDE HEIGHT ADJUSTER........................$249.00 ea.
• Designed to fit over your OE Koni shock absorber or with item 17.
• Adjustable spring platform allows 1 in. ride height adjustment.
• Spring combinations available for street or track.
• Four wheel alignment required after lowering.
and shorter spring caps:
LOW PROFILE UPPER SPRING CAP
a.'92-'95 RT/10..................................$45.00 ea.
b.'96-'01 GTS and RT/10..................................$49.00 pr.
• 9mm shorter than OE spring caps to lower ride height 1/2"-5/8".
another option is different springs from Eibach and others
Serious Eric
Austin, Tx., US.
With 1.75 coils cut out of front and rear springs it handled incredibly well. Lightning turn-in and stuck like glue in the corners, but I couldn't live with it ... intolerably low. Not a driveway transition made that it wouldn't scrape on. Also real risk of high-centering over convex transitions.
Got another set of stock springs and took out 1 coil in the front and 3/4 in the rear ... perfect. No more clearance problems and it still handles way better than stock.
ROIII
