Clear bumper lights
V
VIPER BAZ UK
ENGLAND
Easy to fit pull out rubber **** (were brake cooling hose goes) put arm in undo two bolts and put new ons in might need to put wheels on a lock to do it....
Neil - UK
ENGLAND
Here's the proparts
ones on ebay, click viper in the search box and press go, proparts sells clear side marker indicators all the time on ebay, there's 2 sets showing at the moment they always sell for around $40
V10 MOJO
Youngstown, Ohio
i cant get those [******] bolts off, cant get my arm in there well enough. any other way to do the job? fog lights werent difficult, i could reach those well enough, these bumper lights are a bear though
Neil - UK
ENGLAND
turn your steering wheel on full lock, gives a bit more room, getting the nuts off is a pain, I found there was room for a spanner in the opening, small hands or double jointed helps :) wait till you try and put the nuts back on......
thats the hard part.
V10 MOJO
Youngstown, Ohio
i finally got em in, i think i developed a new joint in my forearm doing it, LOL.
anyway, i noticed the replacement bulbs are yellow and the original are clear. do these light specifically have to illuminate yellow? i tried both colors and prefer the clear with clear look
Snake Bitten
Southern Kalifornia
Use one of these...9mm x 10mm...the nuts are 10mm...Installation is way easy, especially with the offset...get a whole set, you'll use them alot on the viper...
V10 MOJO
Youngstown, Ohio
i just looked at my wifes benz, its got yelloow bulbs for the clear side lights so iam assuming that yellow bulbs are required?
Anthony - 98 GTS
Houston, Texas
Yellow are "required" by law. Stick with the clear if you like it better.
It's not like we all have the "required" front plate.
Casey
Valparaiso, IN.
Just installed my Clear Lights. Pretty easy overall, although it took me 25 minutes of effort on the bolt nearest the tire to figure out I needed a Ratcheting Combination Wrench! Then it took only a few minutes a side.
What is a Racheting Combinatin Wrench you might ask?? Well, take a look at Snake Bitten's picture above and you'll have it!! :laugh: Next time I will remember to do a search before I begin the task, would have saved me some time!!
I used a 3/8 inch, it was not offset, but I imagine that would make it even a bit easier!
Good advice Snake Bitten!! A little late, but good advice!! :p
coronamartini
