ruckdr
Try Wal Mart; my son and I did his non-Viper a couple years ago with a kit fro Wal Mart. I think the kit was $19.95, and included all the sand paper, and polish and sealant required.
Later,
Later,
3M makes a great kit that I have used. It's a multi step polishing program that gives fantastic results:
3M™ Headlight Lens Restoration System US 3M Automotive head light lights headlight headlights tail taillight taillights plastic plastics cover covers fog fogs foggy fogged cloud clouds cloudy clouding clear clears clearing dull dulled yellow yellow
Only downside is that the kit is over $500.
I'd recommend against trying to break the seal on the lens. The fogginess is generally on the outside of the lens, not the inside. You have any pictures of the lenses?
Used this kit and the lens are all cleaned up! They don't look like a brand new set, but they are clear and you can see through them again without making the car look it's age. This is exactly what I was after.
Thanks again guys!
Now, everyone go out and polish something today
you cant do anything if they are yellow, that is due to the plastic breaking down. But you can sand them with 1500 (wet sand with a little detergant) then buff with some polishing compound (I use ultra cutting cream) You will need a real buffer to do this in order to generate the heat/force required for the compound to break down as it polishes. Note they will not be "as good as new" but will look alot better then before.
The 300 uses them on the fog light covers - and they crack easily under heat...Do any cars use glass these days?
